will jato wheels fit a rustler
simple question will jato 3.3 wheels fit my rustler an what do i need to run them?
Only the rears will fit. they have the same exact offset as the front electric rustler wheels. You can run them on all 4 corners, the rear will just be wider than stock.
The fronts are totally different |
The jato fronts are the same as the nitro rustler fronts - If you change the front spindles this works well as it gets rid of the bushes for bearing - Similar to the RPM setup.
I run this setup on my pede... |
what about bandit rear tires
| All times are GMT -4. The time now is 12:35 AM. |
