-   -   Motor Size For rcm Mount? (https://www.rc-monster.com/forum/showthread.php?t=13644)
Pedebeater 07.18.2008 08:06 PM
I will be getting a rc-monster mount for my upcoming hyper st pro, and was wondering if an align 600xl motor would fit? The only reason I ask is because its about 43.3mm wide. Will it be too wide?
Thank you,
PB
lincpimp 07.18.2008 09:59 PM
Thank you,
PB
Hey PB, it should work fine. The hyoer st has a chassis brace that raises the diff bulks up a bit over the chassis, like 2mm. I have also used the rcm hyper mount on a hyper7, flat on the chassis with a c50 maxx motor, which is the same diameter as the align. So it will work fine for you.
Pedebeater 07.18.2008 10:17 PM
Thank you very much. That is exactly what I was looking for.
