Serum, can i copy your bl savy mount?
hey guys i'm thinking about picking up a savage roller so i can stick in a 9920/7xl.
where do i start with motor mounts? i'd get the rcboyz conversion but its a little pricey. i've seen the L-profile plan in a different thread. could i just print that out and tell a machinist to cut it out for me in 6061 AL? i do use the search button :o |
Hi Hernz! welcome to the boards!
That l-profile mount is not my design, but you can use it, it's from joeling i believe. The plate i made is from 10mm thick 6061 aluminum. |
do you have a diagram of your plate? i think yours is adjustable vs joelings? sorry
bl savage, must have! :eek: |
Joelings is adjustable as well! it uses the stock mounting points from the nitro engine.
I don't have got a drawing or anything of the plate i made. |
| All times are GMT -4. The time now is 10:39 AM. |
