Robitronic Overloader 2
The Overloader2 is a high performance computerized battery maintenance system. Capable of charging, discharging, cycling and conditioning multiple rechargable battery types, with very high output power, a customized display with expertly designed software and programming controls.
Features• Perfect for electric cars, trucks, boats and planes • 1-12 cells charging & discharging (for Glowstarter & Batteries for planes) • Handling NiCd / NiMH / Li-Po / PB / Lixx battery types • Graphical display show charge, discharge and cycle curves • Storing up to 10 different battery configurations • Performs 1 - 10 cycles for NiCd / NiMH only, and stores capacity and voltage date • Break-in electric motors or operate commutator lathes • Heat glow plugs for nitro engines • Operate tire warmers • Adjustable language (English, German, French) • Restart of charge and discharge after a loss of power • Intelligent cooling fan control system for better charge efficiency • LCD contrast, fan operation, temp scale and sound cues are fully adjustable • Popups for information and warnings http://www.robitronic.com/files/news...display_en.jpg Specification• Case: Aluminium, red anodized • Case Size: 176x134.7x52.9mm • Weight: 720g • Cooling System: 3x Fan 40x40mm • Input type: Input cable w/banana plugs red/black • Output type: Banana jacks black/red • Input voltage: 11-15V • Battery types: NiCd, NiMH, LiPo, Lixx, Pb • Battery Memories: 10 • Language: English, German, French • Finish sound: 9 Specific for NiMH/NiCd • Charge mode: Linear, Impulse, Reflex, Auto, 4-Step • Cells: 1-12 • deltaPeak/cell: 1-30mV • Peak-Lock time: 1-50min • Trickle current: Off, 10-400mA • Limits of discharge current: 1-6 cells - max 20,0A • Cutoff voltage/cell: 0,5-1,2V • Cycle mode: Off, L->E, E->L, (E)L->E • Numbers of cycles: 1-10 • Cycle wait mode: Time, Temp • C->D Delay: 1-240min • D->C Delay: 1-240min • C->D temperature: 20-70°C / 68-158°F • D->C temperature: 20-70°C / 68-158°F Specific for LiPo • Charge mode: CC-CV • Cells: 1-4 • Charge end voltage/cell: 4,2V • Limits of discharge current: 1-2 cells - max 20,0A • Limits of discharge current: 3 cells - max 13,5A • Limits of discharge current: 4 cells - max 10,0A • Cutoff voltage/cell: 2,7-3,7V Specific for Lixx • Charge mode: CC-CV • Cells: 1-4 • Charge end voltage/cell: 3,3-4,3V • Limits of discharge current: 1-2 cells - max 20,0A • Limits of discharge current: 3 cells - max 13,5A • Limits of discharge current: 4 cells - max 10,0A • Cutoff voltage/cell: 2,0-3,7V Specific for PB • Charge mode: CC-CV • Cells: 1-6 • Charge end voltage/cell: 2,35V • Limits of discharge current: 1-3 Zellen - max 20,0A • Limits of discharge current: 4 Zellen - max 15,0A • Limits of discharge current: 5 Zellen - max 12,0A • Limits of discharge current: 6 Zellen - max 10,0A • Cutoff voltage/cell: 1,8-2,3V Motor break-in • Run Time: 1min - 23h 59min • Voltage: 0,1-8,0V • Current: max 12,0A Glow-plug • Voltage: 0,1-2,5V • Current: max 12,0A Tire warmers • Temperature: 45-75°C / 113-167°F • Voltage: 13,5V • Current: max 12,0A No. RS152 Overloader 2 http://www.robitronic.com/files/news...KW18/rs152.jpg |
Hmmm....that looks a lot like two other chargers.....
Stupid question: how does it warm your tires? :eyes:
Only 4 cell lipo...
Not much use to me... What other chargers does it resemble, cause it looks familiar to me too. |
Looks like a Trinton 2 with a different case.
http://www3.towerhobbies.com/cgi-bin...&I=LXHDJ1&P=ML
The Ice (above), and its rebadged stepsister, The Teamcheckpoint TC1030 http://www3.towerhobbies.com/cgi-bin...?&I=LXPYT8&P=7 |
What the hobby needs is a good 20s lipo, 10A charger with a 840w power limit, that takes anything from 12vDC to 50vDC+.
lol or 240AC
Dosen't look too much like an ICE but more like a Triton. Any estimated price?
| All times are GMT -4. The time now is 04:20 AM. |
