-   -   Brushless Warhead Revamp (https://www.rc-monster.com/forum/showthread.php?t=13854)
brushlessboy16 07.27.2008 09:58 PM
Hey guys, i finally got a new project.. I ended up getting Takedowns warhead :D
He sold it to a guy on RCU and i traded strait across for my raze roller to roller.
Well i plan on Racing the truck at the Jump Jam on August 16th.
Down to Buisness, i plan on using..
-Mamba Max
-5s 4000mah Zippy lipo
-Feigao 8xl-C (finned can)
-Geared 17/44 through an e-savage transmission- Geared for 44-ish
-Badlands MT tires on stock rims
http://i152.photobucket.com/albums/s...10/warhead.jpg
http://i152.photobucket.com/albums/s...010/Rcs029.jpg
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.736842105263158
Other Ratio: 1
Spur Tooth Count: 44
Pinion Tooth Count: 17
Total Voltage: 18.5
Motor KV: 2084
Tire Diameter (inches): 5.84
Tire Ballooning (inches): .2
Motor Current Draw: 80
Motor coil Ω: 0.0073
Spur/Pinion Ratio: 2.59 : 1
Total Ratio: 14.86925 : 1
Tire Circumference (inches): 19.6 inches (497.93 mm)
Total Motor Speed: 37336.94 RPM
Vehicle Speed: 46.61 mph (74.88 km/h)
Estimated Adjusted Speed: 44 mph (70 km/h) - 6% loss
Effective KV Value: 2018.21
KT constant: 0.65 oz-in/A
Motor Torque: 0.27 ft-lbs
Final Torque: 4.02 ft-lbs
Final Power: 1480 watts (2 HP)
trev3813 07.27.2008 10:15 PM
ah nice build, my e-revo will be faster
Takedown 07.27.2008 10:39 PM
I cant beleive he took the raze over it. But you know its AD... Anyways good luck on the build.
brushlessboy16 07.27.2008 10:40 PM
stop hating on duratrax ryan, raze was a great car
Takedown 07.27.2008 10:44 PM
If I was hating duratrax I would hate the warhead and I dont hate the warhead. The raze is old and from what I constantly hear from you it has some serious issues with a brushless combo installed.
brushlessboy16 07.27.2008 10:47 PM
the diffs that a refused to shim initally? yep, that explains it
brushlessboy16 07.28.2008 12:21 PM
Few questions guys,
1. are Feigao 540c's pressed can?
2. Where can i get some Rc-Monster Stickers?
trev3813 07.28.2008 12:27 PM
http://www.rc-monster.com/proddetail...od=rcmstickers There ya go!
brushlessboy16 07.28.2008 12:32 PM
thats going to force me to buy more from mike, lol shipping costs more then the stickers
bruce750i 07.28.2008 12:35 PM
540C finned has threaded end bell with a set screw.
brushlessboy16 07.28.2008 12:39 PM
yay! so i dont have to wrestle with it to change bearings :D
BL_RV0 07.28.2008 12:40 PM
If you e-mail Mike, he can ship in a padded envelope for about $1 he told me.
brushlessboy16 07.28.2008 12:43 PM
that makes it a whole lot easier :D
BL_RV0 07.28.2008 12:45 PM
Yeah, I had the same problem whe ordering a bore reducer.
brushlessboy16 07.28.2008 12:50 PM
ill probably throw new bearings in the motor just to be safe
