problem with neu end cover
hey guys, just wanting a quick question answered in regards to the neu rear motor cover.
i ordered a 1512 2d S from castle, arrived yesterday. its a new version with 4 hex screws in the end, and i have the updated motor cover. BUT on the motor there are 3 wires poking out and on them there is a bit of clear plastic, then there is thick black plastic. the motor cover gets on until it hits the black rubbery thing. (obviously protection for the wires) so i figure i have to force it on and it will be held by the rubber, but just wanted to make sure. it seems as if the cover is too big and would just slide off if these grommets or what not were not there. so guys help me!:yes: ryan |
Anyone??
Just get a drill bit and make the holes a little larger.
I dont have any clear plastic or thick black plastic, just 3 colors of heat shrink and the motor cover slid over it, tightly. Maybe its some new wire covering.. Im with blunten just open up the holes on the cover
http://i278.photobucket.com/albums/k...endbell001.jpg |
If you don't have a set of drill bits laying around a body reamer should work just as well.
Yeah I would just make the hole a bit larger. Not to large, or that would negate the point of the cover, of course.
4 Attachment(s)
ok i will take a pic of it to show you. it was made this month.
here are some small pics... stupid PHONE! i will get better ones later. hopefully you can see whats happening. used a reamer, very soft, and smooth plastic... great to work with. better than a drill as i have more control... mike will have to update his files again i guess. also now its pretty loose, what do you guys attach it on with? i dont wanna stick it:no: unless i really have to.:oh: |
updated, with some pics, glad to know that castle/neu are constantly improving the designto make them last!
| All times are GMT -4. The time now is 03:57 AM. |
