-   -   Why more current? (https://www.rc-monster.com/forum/showthread.php?t=13941)
myndseye 07.31.2008 10:09 PM
Why more current?
When we discuss big motors like the 1521's and up by Neu, why is it that we figure that they require more amps? Is it just because they are physically bigger? You would think that a similarly rated (kv) motor, on a larger scale should need less amperage to do the same work as a smaller can motor. Ten amps through the windings creates a field of larger magnitude in the larger motor, correct? That should create more electromotive force to overcome the load, right? Should not the smaller motor need more current (at same voltage) to build a field large enough to get the same amount of power out?
Some smarter people than me :intello:, please chime in here and set me straight if I'm wrong.
pullinteef 07.31.2008 10:19 PM
I'm sorry, I couldn't make it through your post, I was too mesmerized by your avatar :oops:
brushlessboy16 07.31.2008 10:25 PM
oh come on...:slap::angel:
brushlessboy16 07.31.2008 10:26 PM
i think its Because the guys running 1521 and 27s are running them in big trucks and its just more work for the motor
coolrunnings 08.02.2008 02:48 AM
That avatar rocks!
