-   -   Hydra 120 Braking Issue (https://www.rc-monster.com/forum/showthread.php?t=13977)
Takedown 08.02.2008 07:30 PM
I am having issues with setting up the brakes on my Hydra 120 ESC. I am running it in my e-maxx on 4s lipo with a 50-55 600kv outrunner in direct drive mode. When Im driving and I tap the brakes just enough to slow down it automatically flips into reverse right away without even giving the brakes a chance to kick in. I know its a boat esc but is their any way of fixing this issue. All I need is about 2-4 secs for braking before it kicks into reverse and Ill be fine. Is their anything that will help fix it such as the pi-stix adapter or does the castle link have a proportional braking setting? I really would liek to get this fixed. Thanks to all that help.:yes:
Takedown 08.02.2008 07:38 PM
Also when I disable reverse and I try stopping from forward their is no brakes.
lincpimp 08.02.2008 09:06 PM
Boat braking is usually just enough to stop the prop moving, and then it switches to reverse. As long as the prop stops for a second, it is ok for it to go into reverse, as water does not "grip" the prop like the ground does to the tires. Sounds like you will have to go forward only with mech brakes...
I have setup a hydra with the castle link and do not remember a different brake setting. I suppose that you do not have a castle link?
Takedown 08.02.2008 10:54 PM
Thanks for the help linc but I fried it today after a short run which is sort of a bummer. All the more excuse to send it in and get a new one back and resell it for retail and then buy a MMM.
http://i301.photobucket.com/albums/n...cture006-1.jpg
http://i301.photobucket.com/albums/n...Picture007.jpg
Takedown 08.02.2008 10:55 PM
Weird thing is it just quit and smoked... Never even got warm and reverse was disabled.
lincpimp 08.02.2008 10:56 PM
A MMM does sound like the best bet...
Takedown 08.02.2008 10:58 PM
Its definately the next thing on my list right after the 1/5.:yes:
coolrunnings 08.03.2008 07:14 AM
I was always told the hydra had no brakes.
brushlessboy16 08.03.2008 10:00 AM
-from castles website
"The HYDRA™ is intended for exclusive use with
boats only. Use in any other vehicles or aircraft is
not covered by warranty and will not be supported
by Castle Creations, Inc.
HYDRA 120"
Takedown 08.03.2008 12:13 PM
HYDRA 120"
Yes, I am 100% aware of that. To get it replaced it costs $105.:oh:
bensf 08.03.2008 02:00 PM
Well that looks like a boat to me.:wink:
brushlessboy16 08.03.2008 02:01 PM
yeah dont you see the rudder?
BL_RV0 08.03.2008 11:50 PM
No, but I see 4 black, rubber props. :wink:
