-   Mini truggy (https://www.rc-monster.com/forum/forumdisplay.php?f=43)
-   -   best brushless set for crt.5? (https://www.rc-monster.com/forum/showthread.php?t=14018)
Burnsi 08.04.2008 11:26 AM
hi,
first sorry for my bad english :)
i want a brushless set for my crt.5
i ordered a mamba max 4600 set.
i wanna use a 12 gear pinion and 3s lipo.
was this a good ides or will the motor be to strong/fast for the car?
thx
jnev 08.04.2008 01:21 PM
The 4600 motor will work, but also heat up a lot. It is not quite big enough/powerful enough, even on 3s, to push around the CRT.5comfortable without heating up. I'd recommend the Feigao L size motor instead of the 4600. You'll just need to pick the right KV motor you want with 3s. The 8L and 9L seem to be most common on 3s though. You'll just need to gear up (around a 16t pinion) to get decent speeds. :yes:
Burnsi 08.04.2008 01:46 PM
a few guys at german forum told me the mamba is to powerfull for the crt.5
can you give me a link for this motor?
you say its to small for this car?
jnev 08.04.2008 04:04 PM
Yes, the Mamba Max motors are too small for the CRT.5. Here is a link to the motors in the rc-monster store:
http://www.rc-monster.com/brushlessmotors.php
Burnsi 08.19.2008 12:43 AM
hi,
thanks for your help but i cant find a feigao 9l on this site.
maybe you have a suggestion for alternative motor?
do the 9l have a 5mm shaft?
jnev 08.19.2008 02:24 AM
I also can't seem to find it in the RC-Monster store for some reason. Here is another place to buy it:
http://www.impaktrc.com/product_info...oducts_id=2334
DRIFT_BUGGY 08.19.2008 05:33 AM
Yes, the feigao has a 5mm shaft
Burnsi 09.09.2008 02:58 PM
damn, i cant find the right stuff for my crt.5
will the traxxas velineon work fine for my car?
http://cgi.ebay.com/NEW-Traxxas-Veli...mZ200253320212
i have 2 zippy r 3s 4150mah lipos.
BrianG 09.09.2008 03:02 PM
For 3s, the MedUsa 3300kv 50mm (5mm shaft) would be ideal IMO. Much better than a Feigao, and cheaper than a Neu.
Burnsi 09.09.2008 03:03 PM
and wich esc?
mamba max, monster max?
BrianG 09.09.2008 03:06 PM
The regular MM would be just fine with an external BEC. The MMM would work too, just a little overkill.
I currently am using a MM/4600 motor on 2s geared for ~25mph and it gets a little too warm for my liking (~160*F). A ~3300 kv motor on 3s would be much better.
Burnsi 09.09.2008 03:15 PM
where i can order a cheap mm?
in germany is hard to find castle stuff.
lincpimp 09.09.2008 03:18 PM
ebay?
You could use a Kontronik esc...
