What do you think????!!!!!
Hi guys,
I want an opinion about this motor to convert my e-maxx in brushless: Motor Brushless 43/11 55A x Raptor E550 - E620 SE Alimentazione: 5-6S Li-Po Numero giro/minuto volt(rpm/volt): 1050Rpm/V Assorbimento ampere continuo: 3-55A Min/Max Assorbimento spunto max: 75A/5s Resistenza interna: 19,6 ohm Dimensioni: 43X62 Diametro albero: 5mm. Peso: 280g. it's used usually for the elicopter and it has a lot of torque I heard. I'm thinking to use as a spur 40 and pinion 22 or 25 but my doubt is: is the motor robust enought to run with stock e-maxx? Please help me. Willett :lol::lol::lol::lol::lol: |
It would work for a direct drive motor (in place of the spur and slipper, bolted into the tranny) probably.
I think you need to stick to something much simpler and less experimental, such as a nice inrunner motor; 9XL on 4s lipo with Mambamax for example... |
OK Suicideneil, thanks for the suggestion.:lol:
| All times are GMT -4. The time now is 03:58 AM. |
