-   -   Convert LST to Muggy??? (https://www.rc-monster.com/forum/showthread.php?t=14106)
lucias 08.07.2008 07:14 PM
Can I convert my LST to a Muggy? If I bought a chassis and center diff.. is the rest of it the same? I haven't looked at a parts diagram that would be to easy...:oops:
ilpufxit 08.07.2008 10:06 PM
Not that easy
The arms and shocks match but you'll need a lot more parts. You can pick up a Muggy pretty cheap if you look around, well worth it!
bdebde 08.08.2008 12:21 AM
I believe the LST shocks and shock towers are different than the Muggy, LST has longer shocks. Also the front and rear diff ratios are different 3.3 for the LST 4.09 for the Muggy.
lucias 08.08.2008 12:24 AM
dang it... it was a thought.. do i need to get the stiffer chassis bdebde?
bdebde 08.08.2008 12:39 AM
I would at least get the factory upgrade hard anodized chassis, the stock (silver chassis) is a bit weak. I see some rollers on ebay from time to time that already have the upgrade chassis, that would be the way to go IMO.
lucias 08.08.2008 01:57 AM
I guess i will have to be patient... Grrrr
