-   -   1/8 Onroad? (https://www.rc-monster.com/forum/showthread.php?t=14127)
BL_RV0 08.08.2008 11:54 PM
1/8 Onroad?
Hey, I've got a few spares I'd like to put to good use. I was thinking about using them in a 1/8 onroad like a GTP or similar. I've only owned 1 or 2 onroads, and would like to get more into them. Power system would be a Hacker C50-Maxx, MM, and 5s. (I decided to use an outrunner in the buggy, because I can't gear it low enough, and now I don't have to buy a 4s pack. :yes: I know next to nothing about onroads, so if you could provide some suggestions, all help is appreciated.
gimpygolden 08.09.2008 12:05 AM
Hey,I have an Ultra GTP with a Neu 1512 2.5d on 5s and it is a blast. It's a pretty tough car,only had to replace rear axles so far. I upgraded to cvds seems like a stronger/smoother setup.
Also you might want to consider foam tires as the rubber ones don't hold up to brushless if you stay on it alot.
brushlessboy16 08.09.2008 01:17 AM
heres a good find
http://www.rctech.net/forum/r-c-item...na-onroad.html
What's_nitro? 08.09.2008 03:09 AM
Originally Posted by brushlessboy16 (Post 199831)
Looks like a deal to me; you could sell the engine and get back some of your money. :yes:
Q: Where can I get a front brace like that kit has? (from the center bulk to the front diff brace). :neutral:
BL_RV0 08.09.2008 10:58 AM
What's the spur's tooth count on the 1-speed kit?
