-   -   What diff oils Losi 8T Brushless (https://www.rc-monster.com/forum/showthread.php?t=14139)
gramey 08.09.2008 05:19 PM
:smile:I've bought a new Losi 8T RR which I'm converting to brushless with a Teknorc V.3 kit, Neu 1515-1Y motor using an MGM 16018-3 esc and Flightpower 4S 25C 5000mah lipo's. my question is what would be the best combination of diff oils for this set up, hard packed loose topped track?
I run 5/7/3 in my nitro 8T but I think most people are going a lot higher with the B/L especially in the centre diff:smile:
jayjay283 08.09.2008 06:50 PM
im running 10/30/7 , I dont race though, more of a closed construction site anarchy derby.
FG101C 08.10.2008 05:32 AM
7/10/5 is pretty good. 10/10/7 works well to.
Matthew_Armeni 08.11.2008 11:57 AM
I would stay with what you have first and see if you like it. A lot of the guys that run thick center fluid use motor brakes, it helps prevent unloading during braking. I run my 8T race roller with the Tekno conversion setup as it came out of the box and it feels spot on.
gramey 08.11.2008 04:04 PM
Thanks for the advice guy's, I shall be using the mechanical brakes as this was the main reason I went with the Tekno conversion to retain the stock brakes.
