truggy brusless conversion
hey guys i have a kyosho st-r and i was thinking about going brushless what are the things i will need can you help point me in the right direction thank you!
bl conv.
also is the rc monster bl. motor mount for the kyosho st-r?
Hey,I'm currently doing an ST-rr. The Kyosho motor mount Mike(Rc-Monster) sells is the one you need http://www.rc-monster.com/proddetail...rcmkyoshomount
You'll also need a battery tray http://www.rc-monster.com/proddetail...MFPbatterytray order size according to the battery you choose. For batteries Li-po is the way too go. I use PolyQuest 5s http://www.rc-monster.com/proddetail...=PQXP5s500025c but there are alot of less expensive batts out there. Try a search on Zippy or True RC Motor wise can run from $255 for a Neu 1515(best) too $70 for a Feigao (entry level). Esc you can go the tried and tested Mamba Max(MM) http://www.rc-monster.com/proddetail..._MM_ESC&cat=21 Great for 4s Li-po also somewhat successful on 5s. With this one you will also need a UBEC of some kind like this one http://www.rc-monster.com/proddetail...stlebec&cat=21 Or the better choice the Mamba Monster Max (MMM) http://www.rc-monster.com/proddetail...steresc&cat=21 There are also some nice looking Esc/Motor combos coming from CastleCreations http://www.castlecreations.com/produ...a_monster.html supposed too see these end of the month,but who knows for sure. Also you'll need some pinions http://www.rc-monster.com/proddetail...1pinion&cat=40 size dependent on choice of setup. The plastic Kyosho Spur http://www.rc-monster.com/proddetail...YOIF148&cat=40 is also a good idea too reduce pinion wear but not necessary. A good place to check out to configure your setup and play with some numbers http://www.scriptasylum.com/rc_speed/_top_speed.html Your diff ratio=4.3 spur =50 or if plastic =46 Another must read for Newbs is here http://www.rc-monster.com/forum/showthread.php?t=5115 Any more Q's ask away,everyone is here to help |
Also you can ask Mike any Q's directly reach him here sales@rc-monster.com He's a busy guy so be patient for a reply.
st-r
wow thanks for the info are you using the controller brakes or the mech. brakes that are on the car.
On my ST-rr I am using the mech brakes because I am only using a Medusa 30-60-1600 motor which may be small for a truggy and I don't want thing to heat up too much.
All my other conversions are motor breaks though. |
| All times are GMT -4. The time now is 07:52 AM. |
