Diff Fuid suggestions for E-Revo
I would like any suggestions for diff fluids on a Erevo.... I was thinking the following....
Front 10k Rear 7k SYSTEM SETUP Quark 125b / 7xl maxamps (2s2p) 4s 8000 lipo's badland MT tires geared 20/68 any suggestions would be helpful, I ran this setup in my Gmaxx and was very pleased with it......am I able to run it in the Erevo as well... Thanks Again Guys |
wow.....13 views...and no one has any input....im shocked....:gasp:
With electric, it helps to have thicker fluids to take advantage of torque. I run 50k in the front and 30k in the rear. It depends on the track:
Thicker fluids – high-bite, smooth Thinner fluids – low-bite, bumpy |
Well that helps me as a starting point.....since I allready have 30k, looks like all i have to pick up is the 50k...thanks for the input.....
is this a revo conversion with a center diff?
as the new e-revo doesnt have a center diff , you would need the same fluid in both ends |
I have no CD. I didn't have one in my old Gorillamaxx Revo either. They handle/turn with true awesomeness. |
It will be a stock Erevo.....with stock tranny
| All times are GMT -4. The time now is 08:45 PM. |
