-   -   Any plans for a removeable MM mount? (https://www.rc-monster.com/forum/showthread.php?t=14237)
e-mikey 08.13.2008 07:39 PM
I'd like to swap my MM between my erevo and my hyper 7. Does anyone have any pics or ideas on how I can make this happen?
cdis 08.13.2008 08:08 PM
velcro :D
rootar 08.13.2008 08:32 PM
yup velcro and one zip tie does the trick
tc3_racer_001 08.13.2008 10:24 PM
^^+1^^
Arct1k 08.13.2008 10:42 PM
If you want mount everything to a 2" square piece of 1/8th lexan and then use industrial velcro on the back of the lexan to mount it up
e-mikey 08.13.2008 10:51 PM
Thanks guys. Velcro, heh. I don't know why I'm trying to over engineer stuff using steel plates, rivits, magnets, and snorkals. :oops:
Why 1 zip tie?
MTBikerTim 08.13.2008 11:09 PM
Originally Posted by e-mikey (Post 201456)
Why 1 zip tie?
Security. The removable kind are really good for this.
tc3_racer_001 08.13.2008 11:16 PM
all zip ties are removable... afaik.
the bigger they are the easier they are to remove... just use a screw driver or similar to hold down the small tab and pull :)
saved many zipties this way... perhaps im just a little too cheap :P
Unsullied_Spy 08.14.2008 03:52 AM
Velcro works well, but you'll probably need some expensive stuff to do it right. I picked up some Velcro at Walmart and it only lasted a few months before it stopped holding right and I had to zip tie it on. I got a pack of zip ties from Harbor Freight Tools for only a few dollars and it has a few hundred of them in there (plus they're colorful! :p). If you could find some of the zip ties with the little tab on them that you can press and release them that would be the best way to go, zip ties hold on really well.
