BK controller stuck in programming mode! HELP
It was fine the day before but now when i plug the batteries it makes the first beep to program it. The red jumper is in and i check the solder on it, everything seems fine. What should i do?
Thank |
Hmm.. Take the jumper out and see what it does?! That is really wierd, if you cant find a bridged trace somewhere on the board. Also, you might check the jumper itself to make sure it has good contact ie. isn't loose or wobbly.
It does the same thing. I Checked it and it touches each other.
Did anyone ever have this problem???
I'm sorry I can't help you out more. I do need to correct myself from my earlier post:
| All times are GMT -4. The time now is 12:52 AM. |
