Neu 1512 2d f
I have a shot at a 1512 2df motor for under $200 clams and was wondering if I can get 40mph on 3s lipo with a MM in the new E-revo. Thanks in advance for the help.
3S is a value too low for a vehicle like e-revo. You should use at least 4S
I made up my mind...this is my set up...Neu 1512 2 df, MM, 4s lipo, 14/61 gearing. I ordered mod 1 and 32p pinions 5mm, I hope one will work. CCbec. Should I get an RX cap and what does that do? Should I drill air holes in the esc case and add a fan. I'm scapping the stock servos for one 333 0z in, stock ones suck. Do I need any mods to run the single servo? Sorry about all the questions but us newbies to electric need all the help we can get.
a 1515 series will run alot cooler in there
I finally raced my ERevo over the weekend. My setup:
Neu 1512 2d/f MM with fan and holes 4s 8k ThunderPower ProLite Gears Mod .08 - 18/65 Speed - about 35mph For the 10 minute A-main, my motor temp got up to about 135f. Well within the comfort zone of the Neu motor. The MM got up to about 140f. I think this setup could be geared for a little more speed, but I only race and 35mph is perfect. In the torque department, my MT was noticeably superior to the field...It was the only electric in the field...and the winner of the race. The 1512 in an ERevo is just fine. |
7700 Is for 1/10 1/18 vehicles. With more volts you'll run cooler, longer, and with much power. |
| All times are GMT -4. The time now is 02:47 PM. |
