-   -   What's wrong here? Now with video! (https://www.rc-monster.com/forum/showthread.php?t=14338)
e-mikey 08.17.2008 10:39 PM
After this little video (and a short one after it) all connectors are hot to the touch, the motor was very hot, and the esc was hot. All from like 10 seconds. When I take the motor off the spur, it spins fine.
I had something like this happen before, it turned out to be bad solder on the bullet. I checked the this time, one was loose so I soldered it better.
http://i92.photobucket.com/albums/l9...orissue001.jpg
brushlessboy16 08.17.2008 10:42 PM
sounds like cogging, try bumping up your start power
e-mikey 08.17.2008 10:48 PM
I'll try it right now, weird that it's been working for so long, then all of a sudden...
brushlessboy16 08.17.2008 10:49 PM
did you recently change gearing?
e-mikey 08.17.2008 10:57 PM
negative.. I tried medium, then high. It's amazing how quick it all heats up.
I have been changing pinons a lot, yes. But no pinions I haven't already tried. Set screw is tight if that's what your thinking.
brushlessboy16 08.17.2008 10:59 PM
that is probably why, making the motor turn the wheels further per rotation, more load
remember your testing wihtout any airflow over the esc:whistle:
did the problem clear up?
e-mikey 08.17.2008 11:00 PM
In that video the throttle was pinned.
e-mikey 08.17.2008 11:01 PM
no. it's been like this since 6pm. The motor did get blistering hot with the 20t pinion earlier today.
brushlessboy16 08.17.2008 11:03 PM
hmm check the windings of your motor
e-mikey 08.17.2008 11:03 PM
How do I do that? This motor has no screws to open it up.
TruckBasher 08.17.2008 11:13 PM
Hard to see from the video but before the truck rolled forward was the spur rotating or just trying to rotate like going back and forth? If so you might want to check connection between motor and ESC it seems 1 phase is not working/connected properly.
e-mikey 08.17.2008 11:23 PM
I believe it's the motor. I hooked up my sidewinder and it did the same thing.
Any ideas of a next step? I feel the bullets are on there pretty good.
gimpygolden 08.17.2008 11:32 PM
My GTP with neu/quark set up did the same thing. It was a bad connection where the wires attach to esc. I re-soldiered it and all is good.
Arct1k 08.17.2008 11:34 PM
Can you give a close up pic of the wiring - thx
