What pinion for E-revo/MM/Medusa/TRC lipos??
HI!
I am waitng for me MM ESC and Medusa v2 fterburner 2000kv motor! I got two TRC 8000mah 7.4v lipos and I will run them in series on my E-revo! I want about an hour of runtime with these lipos, and speeds around 40mph! What pinion should I get? How many tooth? I am going to get the 5mm bore, mod1 pinion. Or maybe I will have to get the 5mm bore 32 pitch pinion gears since the E-revo uses 32-pitch gears? Is so, which pinion should I choose then? Please help me out here!:) Thanks!!:whistle: |
Just use brian's paramater solver script for your desired speed - you need a the 32p / 0.8Mod pinions.
http://scriptasylum.com/rc_speed/ |
| All times are GMT -4. The time now is 08:50 AM. |
