help me tweak my setup..........
ok, so now that I have a working MMM, I need a little help. With some moderate duty running in the grass, my MAX temps were as follows:
MMM: 140 Neu: 165 battery: 123 Setup: Muggy (12lb monster truck w/ center diff) Neu 1515 1Y (2200kv) MMM v2 Hyperion 6S 4800mah 20C 12T pinion I also have an 18T pinion, but really, I want to know, are these temps ok, or am I too close to a bad place? Outside temp was about 85, and these temps were after about 15-20min running in the grass. Seems everyone else is running cooler than I am. BTW, you guys were right, BL is INSANE!! I'm hooked!! And while I get that people want the feel of mechanical brakes, hitting the brakes on this setup is like dropping an anchor!!! And the MMM is at 60% brake!! |
Perfect temps... the motor is getting too hot when it get up to 190/200 degrees. The MMM is not even close to too hot. |
Yep, for that setup (1515 1y on 6s) those temps are great.
set your brake to 35% itll be alot better trust me. and if you want, set 10% dragbrake ...i dunno thats just my setting and its perfect.
All those temps sound pretty ideal IMO
I like my brake at 50%- you can still do endos is you tap it too hard, but at 40% it just didnt have enough stopping power for me.
how heavy is your truck neil? mine is 12lbs including lipos rtr
11lbs 11oz without batteries. Not so bad really, especially since 4lbs of weight is in the tyres.
| All times are GMT -4. The time now is 09:23 PM. |
