-   -   MM LiPo Cutoff Issues (https://www.rc-monster.com/forum/showthread.php?t=14391)
bensf 08.19.2008 05:06 PM
I'm trying to turn on the LiPo cutoff and when I turn it on, the controller stops working. It will work when it is set to No Cutoff or 5.0v, but not anything else. My batteries are above the cutoff voltage. It seems like its not arming, but I can hear the beeps that says it is. . .
suicideneil 08.19.2008 05:14 PM
Are you programming it via the usb, or buy the remote? I would check to make sure you have the lastest software and firmware, as there was an issue backalong with one of the updates stoppin the esc from working properly when a custom lvc setting was used, or some't like like..
bensf 08.19.2008 05:31 PM
USB. Firmware is 1.17.
bdebde 08.19.2008 05:33 PM
Castlelink version?
bensf 08.19.2008 07:03 PM
Castlelink ver 3.1
jhautz 08.19.2008 07:52 PM
what voltage are you ruinning? The newer MMs dont like to run 5s with the LVC turned on.
brushlessboy16 08.19.2008 08:10 PM
use a custom setting
bensf 08.19.2008 08:54 PM
Its an older one which I was told ran great on 5s. I have the LVC set to 12.4 and I also tried 12 and neither worked.
entjoles 08.19.2008 09:33 PM
i had to drain a little battery (when fresh off the charger) to get it to run on 5s
what is your pack voltage at?
you may want to set your lvc to the correct input! the 12.4 or 12 is for 4s:rules:
try it on custom and at 16v:yes:
bensf 08.19.2008 09:36 PM
It was at 7.6 for each. I also tried and it wouldn't work with 2s either. . .
I'm trying to make it work with 4s, not 5s BTW
entjoles 08.19.2008 09:38 PM
are you using a external battery or a external bec?
on 2s is the red wire back in the plug to use the internal bec?
entjoles 08.19.2008 09:41 PM
if its my old one......ill buy it back , im in need of a esc. for my truck
bensf 08.20.2008 01:14 AM
yea it is. ;) I'm using a CCBEC with it.
bensf 08.20.2008 01:41 AM
http://www.youtube.com/watch?v=Dp4XGeb81Z0
And a video. 1st try is with no cutoff, second is with 12v cutoff.
bensf 08.21.2008 01:36 PM
Still have no clue how to fix this. . .
