MGM Compro 80 & 8S?
Hey guys, is it ok to run the 8s with the MGM 80 or will that push the controller to its limits and fry it?
Is it possible to limit the current draw through the EPA setting on th TX? |
As long as the motor isn't overgeared, you are definitiely fine with that setup. If the current draw is too much, you could kind of reduced the amp draw, but this wouldn't be an effective way to do it.
It is the same exact system I ran for my frist brushless in my TC3.
7cells, 3300GP. It was fast. BTW....what bearing size is the Fegiao 540 motors? 8x5x2.5 mm? or something else.... I want to replace the bearings since one had gone bad. I guess locktight does seep a lil. |
They are either 5x10 or 5x11. I can check a little later unless someone knows for sure.
They are 5x11x5, just replaced mine.
| All times are GMT -4. The time now is 07:59 PM. |
