Markus "SL" 300A ESC .... WTF
I was surfing around and I came across this.
Unsure if this has been posted before. If so here it is again. http://www.gobrushless.com/shop/inde...how&ref=MARKUS WOW see the price of it? That is more then my E-Revo. I understand it is for planes ... but 300 amps/6S with no fan. If was reliable and made in the USA (for the customer support) I would seriously think about getting it ...even at that price. Merc |
I tried to get Markus and another guy in Russia to make those monsters for cars, but no answer yet. I know they can go up to 400 or 450A.
Those are massive..I thought my mgm 224.18 was top dog.
Wow, that's a lot of amps!
It's usually cheaper to go higher in voltage and lower the amount of amps in a high power setup like that would be used in. I also don't know of a motor that would pull that many amps? :lol: |
In that big of a system though, I'd definitely go to a HV setup, but to each their own. Cause you'd probably have to run 2 or 3p to supply that many amps anyways... |
The 300a one = 6600 watts Max cont
CC 110HV at 150 amps (which i remember hearing it will do) equals the same amounr of power with a cooler running setup. And cheaper. |
| All times are GMT -4. The time now is 10:35 PM. |
