-   -   Zippy taps and Hyperion LBA6 Balancer (https://www.rc-monster.com/forum/showthread.php?t=14483)
ffactory666 08.23.2008 11:45 PM
What taps are on the Zippy lipos .
I use a Hyperion balancer and have adapters for TP and JST taps but they don't fit the Zippy ?
azjc 08.24.2008 12:35 AM
Zippys use XH taps Hyperion sells the adapter
ffactory666 08.24.2008 05:15 AM
Ok , i have the JST EH adapters which don't fit and just looked at the JST XH adapters on AMains site which look like the correct ones , thanks :wink:
Never new there were two types of JST taps .
Next problem is i have the older Hyperion LBA6 balancer which i have had for 3-4 years , wouldn't be a problem but my adapters for TP and JST to Hyperion don't fit the Hyperion LBA6 balancer:surprised:
The LBA6 has 8 pins to connect to but the Hyperion to TP / JST adapters i got only have 7 pins , don't get it because i got them from Hyperion ?
Don't tell me the newer LBA10 balancer has 7 pins and i have to buy one to use these adapters .
azjc 08.24.2008 07:43 AM
I have a a LBa6 balancer and the adapters you can buy wont fit, I have a Hyperion 0610i charger that has a builtin LBa10 and I use that.....I havnt found an adapter that will connect the LBa6 to a new tap......kinda makes the LBa6 wothless.......:tongue:
ffactory666 08.25.2008 03:26 AM
Thanks for confirming that , don't know why they changed the connector on the LBA10 from the one they had on the LBA6 . Probably to make people have to buy the new balancer . My LBA6 is like brand new and works great :grrrrrr:
bustitup 08.25.2008 12:59 PM
I'm pretty sure this is on subject...I have this charger Hyperion EOS0606i AC/DC Balance Charger and cant plug my new zippy h lipos balancing tap into it...can someone linc me to what i need...I did a search but not sure of it
suicideneil 08.25.2008 01:58 PM
http://www.maxamps.com/proddetail.ph...I-ALIGN&cat=33
This I believe is what you need- assuming all the different zippies still use the same align style connectors (JST-XH).
