Using my Hyperion Charger..
How many amps should I be charging my 2s2p 6400 mah batterys at, and is there a formula for figuring this out?
I also see people mention charging at 1c. Is this a setting on the charger itself? |
my hyperion 610net would sets a charge amp of 6.4 amp based of your batt total capacity
so 1c would be 6.4 amps for you if your power supply will allow it i have no idea what model hyperion you have or power supply you may have |
I have a 30 amp power supply and the hyperion duo..
So if I had a 5000 mah lipo, I would charge @ 5amps for 1c. Thanks you. |
| All times are GMT -4. The time now is 10:43 PM. |
