-   -   My MGM 16018 catch in fire! (https://www.rc-monster.com/forum/showthread.php?t=14503)
david lamontagn 08.24.2008 05:59 PM
Play with my e-revo for an hour or more this week-end without any problem.
Today, i've plug the pack and give it a little run, and in about 3 second after niail the trottle, ........... Poufffffff!!!! some white smoke around the revo. So i remove the body to see a beautifull and big, big flame on the controller:whistle:
I've un-plug the li-po to save it from the fire.
The negatif input lead have boke inside of the board and short on the input capacitor.
I hope that my 2 li-po pack are correct, i've not try to recharge it.
So i nead a new controller. Maybe a MMM or another MGM i don't know.:whistle:
Jeremy1976 08.24.2008 06:34 PM
Sorry to hear.
coolrunnings 08.24.2008 06:44 PM
A smoked mgm is quite rare, can you tell us exactly what set up you were running? How long have you had it? Also look into getting your 160.18 repaired cause that might be cheaper than buying that new esc which could fail real quick.
suicideneil 08.24.2008 06:49 PM
Smoked MGMs arent that rare, seen a few recently in truth.
Seems like the on-board data recorder on someones 16018 was reading a continuos current of ~150 amps, and spikes of over 300amps, with a neu 1515 1y or 1.5d. Somewhat startling really.
coolrunnings 08.24.2008 06:57 PM
I meant quite rare compared to others I won't mention.
suicideneil 08.24.2008 07:20 PM
Heh, no comment...
magman 08.24.2008 07:24 PM
David, sorry about your MGM. I bought one from Mike ( same as yours) a month or so ago and have run it a few times w/out issues...hopefully it will continue. I run mine w/a 4s and 1512 1YF, if it makes any difference.
azjc 08.24.2008 09:27 PM
IMO there is a lot of jarring going on with off road trucks especially with speeds approaching 50 mph and all it takes is a loose connection to cause a short.....both the MMM and MGM controllers are good...I dont think buying one brand over another will keep that from happenning in the future. I do like to make mounts that have foam and/or female velcro to help absorb the shock
coolrunnings 08.24.2008 09:39 PM
Before you buy a new esc call mike and ask him directly what you should buy for maximum reliability and heck you may want to even ask him what he runs.
TruckBasher 08.25.2008 12:54 AM
Well...to late for that :lol: he sold his truck and will stick with his Baja SS...
bensf 08.25.2008 01:07 AM
I think I remember reading that Mike runs MGMs, but don't take my word for it.
83gt 08.25.2008 07:32 AM
I don't think it's that rare. I smoked my 16018 in pretty much the same fashion. It worked great for several runs, and then released the smoke on plugging in the battery the next day. Strange. It worked for a while after that only on external BEC or RX pack, and then it shot some little flames when the fets went up.
J.
TDC57 08.25.2008 12:26 PM
Sorry to hear about your loss David..
For what it's worth, I've got (5) MGM now, two run great, one has no brakes at high speeds and two are out for software upgrades. MGM, MMM, ETC they are all the same, every time we plug them in, we takes the risk..
Still that sucks sir sorry, if you haven’t already, just send it in to MGM, you should have another one in about 4-6 weeks..
david lamontagn 08.25.2008 04:12 PM
Not sure if MGM will send me a new unit for free:neutral:
My setup was e-revo, with RCM hybriyd diff (buggy ratio) geared 62/22, on 6s li-po
I've run about 5 hour with this setup before the controller catch in fire.
Don,t know the reason:neutral:
gramey 08.25.2008 06:11 PM
6s lipo is presumably 6 cell which at 3.7 volts per cell equates to 22.2 volts, the 16018 is rated as per model number suggests at 18 volts so your running it over it's limit. I was going to go with the 16018 until I realised that it would restrict me 4/5s so I ordered the 16025.
This may not have been your problem but I wouldn't rule it out.
