CC "Stock" motor
Maybe I'm barking up the wrong tree---Is it feasible for CC to build a Delta wound motor for Stock class vehicles? I like to run Stock class (TC etc) but I can't use my CC speed controls on 17.5 motors. I know ROAR would reject it because it doesn't fit the current standard-but they (ROAR) really need to get their head out of their duffle bag. Many tracks use ROAR rules as a standard and if there was a CC motor that ran like a 17.5 it would be very well appreciated. And people could use their CC speed controls. Don
Your are not the only one complaining about ROAR and how they need to change things around to accomadate the new technology/make new classes of racing.
At the very least, they should allow users to set up their ESC to emulate the performance of a 17.5 motor. Maybe they could approve the ESC settings, and then make sure everyone has those settings loaded? A PITA to be sure, but it would allow CC in the game without having to "downgrade" their motors to suit an aging standard...
Some people seem to run roar legal motors just fine on their MM. I think the orion motors can be run without issues.
I also heard that,but only the high power ones;ie 3.5-8.5. I haven't heard of any people successfully running a 17.5 and a MM or Sidewinder. Don
You could try a tekin Redline 632 (3200kv) on 2s. Their redline sensorless motors are similar to castle motors, but there are more kv options.
If Novak KV #'s are accurate, the 17.5 is 2200. I did find that Offshore Electrics has a Feigao 540 S 16T with a KV of 2218. But I really don,t know how close that would get. This idea that it has to be a Wye wind (ROAR) is BS. It makes my CC controls useless for stock class. Don
They specify the wind type? Sounds like they are trying to keep people from finding loopholes. I don't know how the rules are written, but I assume they specify a turn count? If so, it makes sense because you get 1.73x more kv in a delta vs a wye for the same wind. Simple solution: just specify a kv range and be done with it! But that makes wayyy too much sense. :sarcastic:
Yes, they do. Does anyone know if the rotors are "380" size or "540" in Novak 3.5-21.5 motors? How would they compare to a Feigao 540S? Don
The motor must be a sensored type using a six position JST ZH connector model number ZHR-6 or equivalent connector with 6 JST part number SZH-002T-PO.5 26-28 awg contacts or equivalent. Wire sequence must be as follows: Pin #1- Black wire-ground potential Pin #2- Orange wire-phase C Pin #3- White wire-phase B Pin #4- Green wire-phase A Pin #5- Blue wire-temp control, 10 k Thermistor referenced to ground potential Pin #6- Red wire-+ 5.0 volts =/- 10% For clarification pin #1 is on the left hand side of the above connector with the wires exiting the top of the connector and the plastic tangs that hold the contacts in the housing are facing forward. See drawing below. Sensored type compatible speed controls must use the six position JST header part number X-6B-ZRSMX-TK (where the X denotes the style of the header), or equivalent. The power connector for all type speed controls has to be clearly marked A, B, C. on both speed control and motor. A for phase A B for phase B C for phase C 8.X.Y.3 Brushless motor dimensions and requirements. 8.X.Y.3.1 Can: Comment: There were requests to identify the timing of the motor and none was offered as a reference, so there isn’t any requirement for timing to be identified. The motors currently designed to this specification have timing rings that give the user the ability to adjust the timing to some degree. So as it stands now, there isn’t any requirement for fixed timing or a limit to the timing of the motor. Overall maximum diameter is 36.02mm measured at whatever point yields the maximum dimension, excluding solder tabs or lead wires. Overall minimum diameter is 34.00mm measured at whatever point yields the minimum dimension, excluding solder tabs or lead wires. Maximum length is 53.00mm measured from the mounting face of the motor to the furthest most point of the end bell, not including solder tabs, lead wires or original manufacturer’s logo or name. Minimum length is 50.00mm measured from the mounting face of the motor to the furthest most point of the end bell, not including solder tabs, lead wires or original manufacturer’s logo or name. Motor mounting holes must be on 25.00mm to 25.40mm centers. 8.X.Y.3.2 Stator: The stator construction must be continuous laminations having the same overall shape, one after the other without anything in between. The laminations must be of one homogeneous material without cutouts, holes or hollow sections other than for the three slots for the round copper coil wires and the three slots for the screws used to hold the entire can together. The overall stator length parallel to the motor shaft shall be minimum 19.3 mm and maximum 21.0 mm. The thickness of the laminations shall be 0.35+/- 0,05 mm. A “Go/No Go” gauge 14.500 +0.000/-0.005 mm diameter shall pass into the stator, clearing the stator plus it’s windings and the electrical collection ring at the end of the stator. 8.X.Y.3.3 Winding: Only three slot “Y” wound stators are permitted. No delta wound or slotless stators are allowed. Only circular (round) pure copper magnet wire permitted. The three slotted stator must be wound with 17.5 turns of 2 strands of 20 AWG perslot. The inductance for each slot of the stator shall be 102.00 Micro Henries minimum and 108.00 Micro Henries maximum, measured with the rotor removed from the motor. 8.X.Y.3.4 Rotor: External shaft diameter must be 0.125 inches (3.175mm). Only one piece, two pole Neodymium sintered or bonded, or Ferrite (Ceramic) magnetic rotors are permitted. The magnet length shall be 25.0 +/-1.00mmmm not including any non-magnetic balancing material. The magnet outside diameter shall be 12.30 +/- 0.10mm. The shaft outside diameter, where the magnet is mounted, shall be 7.25 +/- 0.150mm. This dimension must be measurable without destroying the rotor. 8.X.Y.4 All motors must have the original manufacturer’s logo or name molded into the end bell and stamped onto the can. A marking or unique feature that is difficult to remove must be integrated into the motor to signify that the motor is for stock competition. 8.X.Y.5 A minimum of two thousand (2000) brushless motors must be available at the time of approval. A minimum of three hundred (300) brushless motors must have been sold to at least three (3) distributors or hobby shops or OEM’s at the time of submittal. The manufacturer has to provide an address of a hobby shop or the like, that any driver who wishes to obtain these motors at the time of the approval can do so. No hybrid (mixing of parts from approved or unapproved brushless motors) allowed. 8.X.Y.6 The maximum retail price of a stock brushless motor shall be $129.00. |
Criminy! Those are the rules for a HOBBY? Sounds more like legalese to me. I'm glad I don't participate in such a restricting event! I do understand the need to level the playing field somewhat, but that's just crazy!
Thanks Patrick, I was hoping you would see this discussion. Are my thoughts unreasonable? I would really like to have the option of using my CC sc's with a "stock" motor. I realize this is not your "problem" and that you and your company are quite busy, but I thought I'd throw it out there. If that ROAR standard could be modified it would be helpful. Thanks for listening, Don
Alright!!!!!!!!!!!!!!
| All times are GMT -4. The time now is 06:23 AM. |
