-   -   Okay to remove power switch from MM? (https://www.rc-monster.com/forum/showthread.php?t=14510)
e-mikey 08.24.2008 08:53 PM
I have a mamba max that lost its power on switch. So what I did was solder to 2 wires together, and to turn it on I just plug the batteries in. I am using an external BEC and 4s.
Could this damage anything? Thanks
MetalMan 08.24.2008 09:11 PM
That is perfectly fine. In fact I remove most of the switches I encounter. They are more of a nuance than anything.
E-Traxxer 08.24.2008 09:13 PM
I find switches annoying too. Why plug in your batteries then flip a switch when you could just plug in your batteries and be good to go?
BrianG 08.24.2008 09:28 PM
Then pull the switch off and solder the wires together? Me, I like to replace the stock open-frame switch (which lets dust/dirt inside and corrupts the contacts) with a sealed toggle like those found at radioshack. Even though it's not needed, I like the 3A+ switches because those switched tend to make a more solid/secure contact. The lower-amp ones still work, but the force needed for the switch action is less and might auto-toggle on a hard landing or something...
azjc 08.24.2008 09:32 PM
if you are running higher voltages when you hook your pack(s) up there wont be the big spark if you use the switch
BrianG 08.24.2008 09:42 PM
Are you sure about that? The switch is just used for programming and to shut the "brains" off. The input caps are connected directly to the power input wires so will spark no matter what, unless there is some circuit I'm not aware of...
bdebde 08.24.2008 10:57 PM
I think because the brains will draw down the caps with no switch and with a switch there is still power stored in the caps.
gixxer 08.24.2008 11:27 PM
I just never turn off the switch. If the battery is plugged in then I am good to go. Really dont see a need for it. If the switch goes like it did on my mamba max then I will just solder the wires together.
hoovhartid 08.24.2008 11:29 PM
I have noticed that if I have run my 6s set-up within the last few hours, then I dont get a spark when reconnecting batteries. But if its been a few days, then she sparks. Maybe just a coincidence. or maybe the caps hold a charge for a limited time?
bdebde 08.24.2008 11:46 PM
Yeah, caps will bleed off slowly.
