Tire Taping ?
So I just put a set of badlands on my erevo. Lots of traction, but they do balloon quite a bit. I currently have maximizer beadlock wheels and the proline molded foams.
Shough I wrap tape on the tire, or the foam? I have read that some turn the tire inside out and wrap it a few times with tape, or should I leave it right side out and put the tape in that way? Also what tape should I use? Thanks guys.. I need to go back to a 17t pinion, as the 19t is pulling a few more amps with these tires compared to my mtr bowties... |
i used duct tape on my badlands and it completely STOPPED the ballooning, yes wrap the tire
one turn of duct tape with about 1/2 inch overlap |
I turn inside out and use the extreme packaging tape - it is glass reinforced... seems to do the job well
http://www.staples.com/office/suppli...&ci_sku=489132 http://www.staples.com/sbd/img/cat/std/s0081250_std.jpg |
Thanks guys, I will try to scare up some of the tape arkt1c linked to....
Funny to see the tires grow, and they are way off balance. What does everyone use to balance the tires? I have heard of modeling clay being used cause it is sticky, but is there anything better? I have a prop balancer so I can do it properly... |
linc you pulled the thoughts right out of my head.
Last night i got my maxx setup and drove it for the fist time in ages with my MMM and i too am running maximizers on badlands because i liked the look and they are all terran. after driving a few questions came to my head 1.) what do i do to stop the balloning 2.) why are they so unballenced 3.) why did i rip the tires right out of the beadlock so to prove that i am not joking heres a pic of my tires laying in the floor ready for taping to be done. [IMG]<a href="http://s116.photobucket.com/albums/o6/GorillaMaxx360/?action=view¤t=P1010001-2.jpg" target="_blank"><img src="http://i116.photobucket.com/albums/o6/GorillaMaxx360/P1010001-2.jpg" border="0" alt="Photobucket"></a>[/IMG] thanks for the thread as it will be very useful to me |
the tape does wonders,I have used duct tape and the reinforced packing tape.
Both get the job done |
I will post back here when I get all of the materials and get some in-progress pics! |
James the PRO's vent ther tire with a leather punch instead of taping . Your tires are going to ballon some what Know matter what you do . There is a reason the PRO's dont tape there tires . |
I would suspect the Pros would use the correct tires for different scenario also. Tape adds weight in the worst place, in the rotating mass.(A bad thing for the pros) Is it not centrifugal force multiplying the tire weight that balloons tires? (not trapped air) They would look like over sized donuts not pizza cutters. What is the weight of air? About .075 Lbs a cubic foot depending on the density. How many cubic feet of air is in a badland tire? less than one. IMO. Around 36-39MPH is when mine start swelling.
Just thought you might be interested to read this as Centripetal and Centrifugal forces are often mixed up...
http://mechanical-physics.suite101.c...vs_centrifugal |
| All times are GMT -4. The time now is 12:17 PM. |
