-   -   Had an EPIPHANY during math class today (https://www.rc-monster.com/forum/showthread.php?t=14583)
MetalMan 08.27.2008 04:05 PM
1 Attachment(s)
So there I was, sitting in a two hour lecture on infinite sequences/series by a British professor (funny guy!), and all of a sudden this hit me (attached):
_paralyzed_ 08.27.2008 04:12 PM
I don't get it, nice shading though
brushlessboy16 08.27.2008 04:20 PM
i see a slipper on the outrunner
Takedown 08.27.2008 04:23 PM
I also see a slipper setup on the outrunner but whats with the two shafts, diff and a solid gear?
MetalMan 08.27.2008 04:27 PM
Correct! It's actually two separate ideas, but I didn't want to draw two motors.
The top is in fact a slipperential with the slipper on the outrunner shaft and that drives a center diff.
The bottom is just a solid shaft.
I will have to explain myself later, for now I gotta get ready for work.
brushlessboy16 08.27.2008 04:27 PM
oh okay. why not just run direct drive :D
Takedown 08.27.2008 04:54 PM
Maybe he wants the nitro spool up feel.:lol:
Semi Pro 08.27.2008 05:13 PM
so the out runner fits in the transmission, like on a revo
lincpimp 08.27.2008 06:03 PM
With a geared setup you can maintain the center diff, use a slipper, and also use an outrunner that may not have the optimum kv for your intended battery and desired top speed. A smaller higher kv motor could be used with a smaller "pinion" on the slipper than the center diff "spur" (like a 36t revo spur on the slipper driving a 46t spur on the center diff)
BrianG 08.27.2008 07:23 PM
So basically, more gearing options. That was one of the things I didn't like about outrunners; you had to make sure to get it right because there are so few ways to adjust gearing
TruckBasher 08.27.2008 08:15 PM
Interesting...well one good thing about outrunners is they promote innovation and not just traditional stuff...
I am yet to find out if it is innovation or just heartache of wasting time/effort :lol:
BrianG 08.27.2008 08:59 PM
IIRC, Patrick (pdelcast) made the apt comparison:
Two pole motors are like import 4-cylinders. They have high rpm/horsepower, but less torque. Neus are like domestic V8's, lots of hp and torque. And outrunners are like diesels with lots of torque but don't like the higher rpms.
I'm too lazy to go find the post, but it's along those lines.
MTBikerTim 08.27.2008 09:01 PM
So is your idea putting the slipper on the pinion instead of onto the diff? Something like the LST slipper would be good for that as it seems to be able to handle power.
Takedown 08.27.2008 09:14 PM
Very well said Brian! :yes:
TruckBasher 08.27.2008 10:16 PM
Agreed spot on Brian....even in pricing they seem to be the same as your comparison....and even what I said innovation....most diesel engine can now run biodeisel or veggie oil :intello:
