-   -   do people bash 1/8th truggies buggies (https://www.rc-monster.com/forum/showthread.php?t=14587)
e-rev project 08.27.2008 05:24 PM
i always hear of people racing 1/8th scale truggies/buggies but is it a good basher. i read they are more solid even compared to lighter jato style trucks? what do you all think
main question is this a low maintenance good off road basher
thanks
brushlessboy16 08.27.2008 05:26 PM
should be, just use alot of loctite :D
BrianG 08.27.2008 05:32 PM
A b/truggy is about as solid a platform you're gonna get IMO. Plus, the way they're laid out makes it easy to work on should you need to replace a diff. The only downside is the sometimes reduced ground clearance due to the flat chassis.
Takedown 08.27.2008 05:33 PM
The reason a buggy/truggy 1/8 in general is a good basher is because weight is spread out evenly and the parts are quite bulked up so its hard to break things. They are more fun to bash than 1/8 MT's in my opinion because they are so much easier to control.
jnev 08.27.2008 06:42 PM
I haven't experienced truggies, but buggies are definitely great bashers. :yes: And REALLY tough as well. I'll be posting a video shortly to demonstrate this. :wink:
e-rev project 08.27.2008 06:59 PM
isn't a truggy a buggy with bigger tires? and same a-arms front and back
BrianG 08.27.2008 07:26 PM
Generally yes. Also they usually are a bit larger, have a wider stance, larger tires, more ground clearance, F/R diffs have a higher gear ratio, and the CD usually has a larger spur. The gearing changes are there mainly to compensate for the greater weight and larger tires.
e-rev project 08.27.2008 07:43 PM
ok thanks screw the jato i need a truggy
BrianG 08.27.2008 08:01 PM
The good thing about Jato-sized projects is that the power requirements are a lot lower, so you can get by quite well with 2s and 3s setups. Cost is lower too. Truggies are larger and heavier so they really need at LEAST 4s to run well, preferably 5s or 6s to keep currents down. My Jato is a squirrely little bugger, but it's tough as nails. The only thing I've broken is a rear shock tower, but that was because I was running with the body off and it caught on something. Cartwheels will do that. :smile:
e-rev project 08.27.2008 08:13 PM
damn this is a tough decision "squirley"seems like a huge downfall for the jato "which i have and would be cheaper" arghhh. but i like easy driving, do 1/8th truggies wheelie i know its a loss of control but it looks cool, can they do it easily. im talking mmm and medusa or cc neu 5s or 4s i have 5s 5000mah zippy h
i just bash
i know wheelies are stupid but i want to show off sometime for people who have no clue what electric can do (DAMN NITRO HEADS) and that is the only way to show raw power MUHAHAHAHa
thanks
jnev 08.27.2008 08:19 PM
Any brushless vehicle will wheely. They all will have the power, its just hitting the throttle enough and having enough traction. My 1/8 buggy can even wheely. :lol:
lucias 08.29.2008 10:38 AM
I want a muggy for a basher... I have a motor and speed controller jsut haven;t found my deal on a Muggy! Keeps the truggy style but in a monster truck way..
maxair45 08.29.2008 10:51 AM
Truggies are buggies with bigger wheels/tires. I'm popping some truggy tires on my lx1 and i'll be racing it in the truggy class.
lincpimp 08.29.2008 11:32 AM
Just get a new erevo, slap some brushless power in it and go play. So far it is my favorite general purpose vehicle, handles well and jumps great. Plus it is cheap to fix and responds well to suspension adjustment.
I favor a MT over a buggy for bashing, as the added ground clearance and taller tires allow a MT to go just about anywhere. Buggies are only really good on the street and dirt. Or very low cut grass. Putting larger tires on a buggy requires quite a bit of re-gearing to get right....
cornolio 08.29.2008 12:16 PM
ive been bashing with MT's ever since i started(tmaxx,emaxx) but when i had my first bl truggy all my MT's turned into shelf queens,truggies are more durable,easy to maintain and a lot easier to drive.only disadvantage is the lower ground clearance.hope this helps
