-   -   Glitch And Twitch With A Cc Bec (help!) (https://www.rc-monster.com/forum/showthread.php?t=14659)
ANGRY-ALIEN 08.31.2008 12:20 AM
Hi...
I need some advice regarding ridding my truck of the glitch 'effect' when I plug my CC BEC into the receiver... The effects are not immediate,
but when the truck rolls out to about 50 meters it goes crazy...:whip: The same thing will happen in the house when I am testing and it's only a
couple meters away. I tried plugging a receiver pack in just to see the difference... There was no glitch or twitch.
What can I do do to fix this problem? I am currently using two servos (steering and gear shift) with a Quark 125B.
Alien
Texas-Pete 08.31.2008 12:21 AM
What RX/TX are you using? Sometimes a lot of glitch is becuase of AM/FM TX's
ANGRY-ALIEN 08.31.2008 12:31 AM
Hey Texas-Pete, I'm still using the stock traxxas RX/TX (AM), But I only noticed the problem when I added this new BEC (the previous one blew up:oops:).
Texas-Pete 08.31.2008 12:44 AM
Welllll.... From what you described...
As your truck/truggy/buggy/etc rolls further away, the signal becomes a little bit weaker, allowing the BEC interference to become stronger . My guess is that the new BEC is giving off a stronger signal that is either greater than your old BEC, or that it is close to power wires... Try moving your antenna further away from the BEC/power wires.... Or try re-wiring your BEC, so that it's further away from your RX/Motors....
ANGRY-ALIEN 08.31.2008 12:50 AM
Thanks Texas.. I'll try a couple combos and see how it goes.
