Quick motor question
Ok, so I might be building up a revo. Would be for the track, thats all the details I give:na:
I need to make 15-20 min run times, and have a mandatory batt swap. Thats the rules I want to go light, but dont want to be pushing runtime, 15 mins is max I can go till I have to swap batts, So a little longer then 15 is good Heres the question, for racing, I dont need power, I just want to run 5, or 6s to be efficient, I dont want crazy power though, needs to be controllable. So im looking at running a NEU 1515 2.5D for 5s, 1.5Y for 6s Any comments on this? I dont want crazy power, just want runtime. What batts should I run? What motor should I run? |
Wow, no one runs 6s huh?
Come on guys! |
you really cant say " Neu 1515" "6s" and "I dont want crazy power" in the same sentence :D :lol:
Afterall, your avatar thing says "More power".
LOL yeah thats true
I just want to make 15 mins, on the smallest lightest lipos. But if its going to be crazy power no matter what on 6s, maybe I will do the 6s for playing around, 4, or 5 for racing? I dont need a over powered track car, just something that is super efficient |
2.5d great for 5s racing and then use 6s for bashing
[QUOTE=BL_RV0;209143]As you can see I'm really enjoying typing with images.../[QUOTE]
Get enough pictures of words and you would never have to type again... but your posts would look like a ransom note:lol: |
haha wow
So you think run a 5s motor on 6 for bashing, 5 for racing? Why not a 6s motor, not enough power? Or what? |
6s would be fine for racing just lower the mah on the pack to avoid getting it heavy.
However running 6s for racing giving you limited options to increase for bashing... |
I dont need anything crazy to bash with. But I guess a NEU 2.5D. I will look around, see if I can find a cheap one
+1...
1.5Y on 6s = 1Y on 4s btw. Plus, Y is slightly more efficient than D. For 6s pack get 3500 mah cells and you should be just fine.
| All times are GMT -4. The time now is 02:40 PM. |
