And another new 100A esc (4-8s lipo)
http://www.hobbycity.com/hobbycity/s...og/SUP-125.jpg
They are called SuperSimple because they come with a limited range of programming functions and are designed to be plug-n-play. A perfect ESC for those looking for something simple to use and economic. Specs: Weight: 85g Size: 70x50x13mm Cells: 4-8S Li Po Constant Current: 100A Max Current: 120A No BEC Timing: 1/7/15/30 programmable PWM: 8/16K Features: Constant current 100A Max Li-Poly 4-8 cells Dynamic Braking BEC: opto Auto shut down when lose signal Slow down at 3.0V per cell Lipo, Cut-off at 2.9V per cell Lipo 0.8V NiMh Programming options: Battery settimg Throttle Rnage Brake settimg 4 options: Direction and Cutoff Type Timing Mode Setting: 1 / 7 / 15 / 30 PWM setting: 8K/16K Note: This ESC is OPTO, with no BEC supplying power to your receiver. You will need an extra power source for your receiver. (such as UBEC or Rx battery pack) If you hear the music tone repeat for more than 3 times, you may need to check your power source to the receiver. More Details:http://www.hobbycity.com/hobbycity/s...idProduct=7341 -Jeff |
Not that new.
it's not? Hmm..
It's new to Hobby City. They haven't even gotten them in stock yet. Was this for sale elsewhere? -Jeff |
Ive known about this for a couple weeks.
a couple weeks is not new?
:lol: It's on Bidproduct. Same esc, but yellow shrink.
Does it have car programming? I would suspect for 30 dollars you will get a 30 dollar ESC, but hey, I could be wrong.
No car programming and it's made by Suppo. A few companies here in the US sell them at a very good price as well. I'm just getting new price for my 6S 150A and 10S 120A ESCs and if I get it by today, I'll be sending them $$$ tomorrow and should have them in about 15 days after they receive the $$$ :lol:. I know you guys are looking for the cheapest car ESC out there and I'll try to make mine at the lowest price possible.
I don't think it's so much looking for cheap but rather reliability at a good price :wink:
Here it is on bidproduct: http://www.bidproduct.com/part/Produ...20ESC_116.html
So it doesn't have proportional brakes? Shame really if it doesn't as I was going to try it for that price. |
Is this the same thing as the TrueRC Volo ESC?
well as i just read, the volo is 5s only - this is 8s....
(and this is hasnt got any car software...) |
The 8S controller posted above is made by Suppo. I just received their 30A car ESC for testing and if it works ok, Suppo will be able to add the car software to any of their ESCs.
This could be promising... Is the 30a a 3s esc?
| All times are GMT -4. The time now is 05:55 PM. |
