-   -   MMM's on the way, now what Nue to occompany it? (https://www.rc-monster.com/forum/showthread.php?t=14749)
shizzon 09.03.2008 02:09 AM
getting pretty close to the purchase of my motor, and just want to make sure i,m getting what i should. I am looking at : 1515 1y (2200kv), 1515 2D (2050kv) and 1515 2.5 D (1650kv). I am currently leaning towards the 2d as it is somewhere in between. looking to run 4s now and 6s later if/when 4s gets too slow, that,s where i would see the 2.5 as being the better choice, but i dont know if it will perform as well on 4s. also i think the 1y wont like 6s too much, getting high on the rpm's. Just want to make sure that my $250 is gonna get me what i need.
RideIcon 09.03.2008 02:39 AM
I want an answer to this too, will gearing matter with the motors? was hopping to hit about 50 on 6s with the mmm
I was going to get the 1y but now i'm not sure if i can run 4s on it. would like to be able to run 4s for longer run time and bashing
this is for an erevo
xcntrk 09.03.2008 09:20 AM
I think you need to consider availability into your equation… I can’t find a decent 1515 can Neu or Teckno-Neu anywhere!!!
Arct1k 09.03.2008 09:48 AM
2.5 is very versatile - 4s it will gear up, 5s is perfect, 6s is insane...
It was my choice... If mike can't get you one there are places with them in stock.
shizzon 09.03.2008 12:05 PM
I was actually thinking of building one from Nue's site, but if i could find one on here i wouldn't mind buying it either. Ive never bought one before so i'm not sure which way is better to go.
neweuser 09.17.2008 12:49 PM
Would a 1515 1/y work good in a E Revo? I may be getting one sometime, and still have all my electronics to drop in. Also, what gearing would work well with the stock diffs if I don;t go to 1/8th right of way?
bruce750i 09.17.2008 01:14 PM
1y is good for 6s, 20-24t pinions / 58-68t spurs. 2.5d on 4s is a little faster than stock twins but w/ lots of torque, depending on gearing.
neweuser 09.17.2008 01:18 PM
I guess my question is what gearing with the stock e revo with 1515 1/y. Meanign, what pinion running 5s, or 4s?
stum 10.02.2008 08:55 PM
I have my 2.5d geared for ~43mph on my erevo on 4s lipo and it does great.. 22/54 it's actually perfect for the race track, just right on the top end and explosive on the bottom.
TexasSP 10.02.2008 11:35 PM
I kind of doubt that at only 24k RPM's. On 6s with a 2.5d you're only good gearing up to about 50 and 45 is about right.
stum 10.03.2008 12:31 AM
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 22
Total Voltage: 14.8
Motor KV: 1650
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 1
Motor Current Draw: 0
Motor coil Ω: 0.01
Spur/Pinion Ratio: 2.45 : 1
Total Ratio: 12.80769 : 1
Tire Circumference (inches): 24.5 inches (622.41 mm)
Total Motor Speed: 24420 RPM
Vehicle Speed: 44.24 mph (71.07 km/h)
Estimated Adjusted Speed: 42 mph (67 km/h) - 6% loss
Effective KV Value: 1650
KT constant: 0.82 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
TexasSP 10.03.2008 09:20 AM
Still doesn't mean the motor can make it. I can put a micro motor on there and make it say I can drive it at 100 mph, it still won't happen.......
The calculator is simply a useful tool to aid you with a setup, it is not the end all be all.
JThiessen 10.03.2008 09:38 AM
I've asked this before, and only kinda got an answer - what RPM should we be shooting for on a Neu? Somewhere in the mid to low 30's is what I presumed. I'm slated to gear mine at 30/54 and run it on 6S - possibly 4S.
TexasSP 10.03.2008 11:05 AM
From what most experience, the 35k to 40k rpm's is generally seen to be most efficient for our uses.
MetalMan 10.03.2008 01:25 PM
35-40k is most efficient for the motor (typically), but at lower RPMs they seem to run cooler. For example, many people including myself have used the Neu 1512 2.5D (2050 kv) on 4s Lipo (~29,000 top RPM) with excellent results. I do run other setups at up to 40K RPM, though, and those work equally well.
