newb ?
can someone show me a diagram on how to use a rx pack instead of an external or internal bec
Here you go
http://scriptasylum.com/rc_speed/_wiring.html fill it out and it tells you how to wire it :D |
Here's another one fromBrianG:
http://scriptasylum.com/forumpics/mm...d_schem_rx.jpg Or just plug it directly into your rx's battery port. |
DO NOT DO THIS UNLESS YOU HAVE AN OPTO ESC - YOU WILL BREAK SOMETHING.
This setup is very specific to where you want to power the esc from the rx battery as the internal ESC BEC has been removed or does not exist! This is very unusual - normally the internal ESC's bec is still left to power the brain board and the red wire on the ESC lead must be removed! Which ESC are you using - Brian's script is the best tool to look at. Quote:
Bustitup, what ESC are you trying to use this for?
well the only esc I have used so far is the mm with bec I have my new mmm but havnt wired it in yet...I have been reading and it seems that you can eliminate a internal and external bec by just using a battery pack eliminating the problems with bec's especially the mmm
did I assume the wrong info here |
btw.. those diagrams you guys sent me from BrianG site were fantastic.....I told him the G in his name stands for Genius...lol
Funny, I always thought the G stood for Gelding... |
Simple Rx pack will do. I've been using them for a long time now and trouble free. I would use a lipo Rx pack if your electronics can handle and needs that much power to work at its full potential. I would still go for a good nixx Rx pack.
Better watch it guys, there may be warning points in store for you! :smile:
| All times are GMT -4. The time now is 08:10 PM. |
