0610iNet/Duo Firmware v1.7 Released
Ne wv1.7 firmware update available.
Reading thru this one, I see Hyperion has realized they tightened up on the resistance of teh input leads too much and that was causing problems. That what was causing my output connection error which I did eventually figure out. I'll get mine updated this weekend. |
Link us up
edit: Scotty |
Thanks for the update I will have to do mine this weekend.
Thanks! I was hoping they'd do something to solve that. It was getting frustrating.
Never caused a problem with me. I wish theyd add cc/cv endpoint adjustment, I don't like it charging my a123's to 3.7V (aparently 3.8V is the maximum spec). If I could adjust it down to 3.5V/cell (like you can on all the cheap sh!tty chinese ones for some reason) then i could run 5s A123 without worrying through my mamba speed controls (rated for 12 cell nickel) and only loose a few mah.
| All times are GMT -4. The time now is 06:43 AM. |
