Recommendations of X2 CRT conversion
Although it seems that there are limited conversions of X2 CRT here, I am considering to have another one. X2 is much more available than others and has plenty support here in my place. Hence, I hope to get some recommendations for the conversion.
I am an Tekno Neu 1515/2.5d that is about to work with a MMM. However, I gave up my MMM because it is too risky to use the MMM even v2. I will go back to use the MM. I would like to ask some options below: 1. 2.5d with MM and 4S (neu energy, I think.) 2. 2.5d with MM and 5S 3. get another 1Y with MM and 4S 4. others Besides that, I will get a RCM Jammin CR motor mount, a battery tray and probably a plastic spur. Finally, what is the gearing do you suggest? |
2.5d's need 5s. I prefer 2.5d's for truggy action. Thus, 5s.
Aso, the spur takes a beating. Metal is better plastic at taking a beating. Therefore, I use a metal spur without hesitation, like the 46T CR spur. I personally haven't run the numbers on the X2 gear reduction to see how much different it'd be from the X1, but assuming a 46T spur with a 2.5d @ 5s, I would suggest a 13T pinion for starters (and have a 12T handy). |
Hi,
I really like it. http://i198.photobucket.com/albums/a...g39/cc01-1.jpg Regards, Joe Ling |
| All times are GMT -4. The time now is 11:29 AM. |
