NEU motor question
are you guys grinding a flat on your NEU motor shafts for the pinions or is locktite doing ok holding the pinions on ?? thanks for the help
Most will put a flat spot.
The new Neu motors come with a little flat spot but doesn't go along the whole shaft. Stick the motor in a bag and poke a hole through it with the shaft (this will keep any debris getting in the motor) and then use a dremel or file to make a flat spot
ok ...thanks guys for the help and tips ...appreciate it
| All times are GMT -4. The time now is 06:58 AM. |
