Gearing questons for the crt.5
I plan on running a medusa motor...Should I get the 5mm shaft or 1/8"? It seems that the larger pinions w/the 5mm shaft might limit gearing.
Also, what are you guys running for gearing... |
it is a 46t mod1 spur - 5mm all the way... I think I am now 18/46 2s 3300 medusa 50mm
As I stated above, I am looking at the same set up as you. The only difference is that I will be running a 6400mah 2s which should give me an extra 5 min or so run time. |
Bye:mdr: |
I'm running this setup with a 15t on stock tires, 6000mah 2s. I get over 20 minutes. I would recomend the 5mm as you know it will never break! Also I don't see how it will limit you. You have to remember that this is mod1 gearing, I don't know where your going to get 1/8" mod 1 pinions. Plenty of gears available from RCM
http://www.myatomic.com/search.asp?k...1200&search=GO
That is how you will run mod1 with 1/8 shaft (bore reducer). Mike carries them as well but the main page/store will not load so I cant link to it. I will be running the bore reducer on my mod1 pinions as well. |
Avoid the bore reducer if you can - the shafts get a fair amount of stress - 1/8 can break, hence Novak's gone to 5mm for 1/10 scale HV.
I broke my feigao 1/8 7L shaft on my crt.5 - Go 5mm if you are buying a new motor - No reason not to. |
This is Mike's bore reducer: http://www.rc-monster.com/proddetail...reducer&cat=40
But like Arct1k said, it's better to use a larger shaft from the start, particularly is larger vehicles. |
I knew of the bore reducer. But he had originally thought that running a 5mm shaft was going to limit his gearing options. No matter what your still using the same pinions so gearing options are still the same.
| All times are GMT -4. The time now is 04:40 AM. |
