E-Slayer build on the horizon
So I made some "impulse" purchases yesterday:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=013 http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=014 I have a ton of Revo spares floating around, so I figured that I could have some fun and "build" a Slayer! I was just going to buy the suspension assortment, but I saw the chassis lot and just had to have it. That way I can keep my tekno revo together, as it was going to be the donor truck. I have a revo tranny that is locked in 2nd gear, with the wide ratio gearing. Going to use that with a hacker c50 13l on 5s lipo. Most likely going to give the MMM a try, but I have a quark 125b as a backup. Not sure on the gearing yet, but I will be using 1/8 buggy wheels and tires. I have a set of badlands, and some crimefighters. Looks like a fun project, should have the parts in by the end of the week. |
After seeing all the goodies you have, I am sure it will be sick. :yes:
Cool, those were great deals for all those parts.
I have the tranny, knuckles, battery tray, motor mount, and body here. The tranny currently has a center diff, which I think I will leave in it. So it should handle well. I think the badlands wil be a good tire for this truck! |
Lincpimp I bought a Slayer tonite and intend on converting it also so I will be following this thread.I allready have a MMM v2 and Tekno 1515/1.5d.Will the Tekno Revo conversion work with no additional needed items since its a Slayer.
Will RCM motor mount allow a pinion and not the clutch.What mods. need to be done?Do I remove the Slayer transmission I am not familiar with the Tekno Revo conversion but I ordered 1 anyway.I have heard though that there is a center diff for the Revo?Slayer?I would prefer the pinion over the clutch.And I assume that I would not need the mech. brakes then.Thanks in advance.
You can buy a center diff for the revo, it should fit in the slayer, but has different gearing (I am not 100% on this, someone else will need to clarify). The internal gear ratios are different between the revo and salyer due to the smaller tires on the slayer. |
Maybe the 1515/1.5d is too much.I think then maybe a 1512 or even a 1509.
60mm 2k medusa worked good in mine on 4s and shifting 20/36. So much air going thu the body it stayed around 120F motor & ESC. How many rpm's does the TRX3.3 make? What kv on 4s would be close to stock nitro speed?
Yes the Medusa is a great option.I have wanted to check these out.:whip:
Got some parts!
Look what the mailman dropped off today:
http://i206.photobucket.com/albums/b...p/DSCF2483.jpg http://i206.photobucket.com/albums/b...p/DSCF2484.jpg http://i206.photobucket.com/albums/b...p/DSCF2485.jpg |
| All times are GMT -4. The time now is 08:43 AM. |
