-   -   top mount motor mounts? (https://www.rc-monster.com/forum/showthread.php?t=14935)
Jabe 09.10.2008 01:17 PM
is there top mount motor mount for hyper st pro?
i saw few photos of those, but does anyone sell those, i tought that they were just protos.
Jabe 09.11.2008 09:19 AM
i mean motor mount like this.
Arct1k 09.11.2008 09:50 AM
Brushlessboy16 mocked up a design and mike was looking at it. You don't need it for a hyper ST pro though.
You can rotate the RCM mount and put the motor opposite the servo. This enables you to put twin packs at the back - I'm swapping mine to this layout at the moment and will post pics at the weekend.
Jabe 09.11.2008 09:59 AM
ok, thanks thats good to know, but i would like my car balanced with no external weights, thats why i asked it.
would that hyper 8,5 motor mount fit hyper st pro?
Sammus 09.11.2008 10:33 AM
Does the spur still clear the chassis if you run the motor at the front like that? or do you have to dremel out a new slot? Would this compromise the chassis rigidity significantly? I also want to do this for battery mounting purposes.
Arct1k 09.11.2008 10:51 AM
The stock spur on a hyper st is 51 - I'm dropping to a buggy spur 46T so clearnance with chassis will not be an issue (no dremmeling). Retaining a 51 would mean some use of the dremel but don't think enough to cause an issue...
Yes the "regular" RCM hyper mount fits the ST with no mods.
Sammus 09.11.2008 10:55 AM
My hb truggy has 50t stock i think, and I run the diff supports from it and the lsp motor mount, still wont fit in backwards with the 46t :( just a fraction a mill too low.
Jabe 09.13.2008 03:08 PM
have you made this swap? got any pics?
Arct1k 09.13.2008 06:49 PM
I tried it today and it doesn't work :( - The front brace stops the motor 1515 mounting properly...
Anyone need a 46 centre spider diff! Arg
Jabe 10.01.2008 10:30 AM
just wanted to show you that its possible to mount motor in front, just need to use bigger gears.
i have 51t in spider and 12t in motor, cant use any smaller with brakes, it allready needs smaller brake disc, as its rubbing on it.
http://i92.photobucket.com/albums/l1...o/IMG_2758.jpg
theres less than 3mm betwene motor and brace.
with 51t spurgear, motormount needs few washers underneath, to clear.
BrianG 10.01.2008 10:43 AM
Yeah, but Arct1k is using a Neu 1515, which is about 44mm in diameter, while the motor in the pic above is probably the typical 36mm.
How about removing the front brace and using a custom piece of aluminum between the center diff and front diff? Should allow room for the motor. Then, you have have to remove the brake, or use a thick plate (spacer) between the motor and mount to allow room for the brake parts...
Arct1k 10.01.2008 10:50 AM
1 Attachment(s)
It was actually slightly bigger - The finned section is 48+ and the main body about 44.
If I removed the red section it would have fitted - My cars tend to get a reasonable about of track abuse (i.e. bad driver) and hence I wasn't to keen to change the brace...
BrianG 10.01.2008 10:55 AM
I kinda like the top-plate brace scheme (which is why my last 2 conversions used it I guess). It makes the car far more rigid than with the stock braces, provides more support for the motor mount/center diff, and provides a couple extra places to mount stuff. :smile: Of course, it's not as pretty...
Arct1k 10.01.2008 10:59 AM
I did that on my GTP 2 but not sure I'd want it on the truggy - 2 packs one side seems to work ok on the ST anyway...
With the 1515 1Y on 4s the 51 spur helps with the gearing anyway...
http://i168.photobucket.com/albums/u180/Arct1k/001.jpg
http://i168.photobucket.com/albums/u...ct1k/002-2.jpg
http://i168.photobucket.com/albums/u...ct1k/003-1.jpg
http://i168.photobucket.com/albums/u...ct1k/004-1.jpg
