LST2 Brushless Conversion
Hi Guys! :smile:
I'm thinking about converting a Losi LST2 to Brushless, with the following setup: - Losi LST2 1/8 - NEU 1521/1.5D 1900Kv - Mamba Monster Max - NeuEnergy 5S 5000mAh 30C Constant 60C Burst - RC-Monster 2 Speed pinion adapter 5mm bore - Acoms 2,4GHz - Self-made motor mount Will this work? Did I forget something? Thanks! |
I think that motor is too "hot" you should be looking at something sub 2000k for 5s... A 1521 1.5D 1900kv would be a better choice.
But I still want a bit speed, like 50 mph or something, do you think I will get 50 mph with the 1900kv and 5s?
I am running a 1500kv motor on 6s, and with 24/59 gearing it does 42mph. The 1900kv motor on 5s will spin faster, so 50mph should be attainable. Not sure if I would go much over 45mph with the stock tires though.
PS you forgot a battery tray - Mikes are very nice...
Or if castle bring out the 1518 size 1800kv motor soon I may give that a try... |
Ok, he has a 45mm x 168mm battery tray, but that NEU battery is 45.5mm x 166mm. So he won't fit.. :whip: ( Maybe I'm stupid but L means Length, W means Width and T height? Or am I wrong? ) |
I'm still searching for a good battery tray..
The dimensions off the battery are: T50 W45 L158 or, I can buy the other 5s from NEU that has these dimensions: T44 W45.5 L166 Btw, will the 25C-50C 5s 4900mAh from NEU be also good enough for this setup? |
THESE will work for the first batt you listed.
I have found the 25c Neu batts to be very good (I use 4300 and 4900). |
Another question, how long would be the runtime do you guys think? With the 4900mAh 5s?
Hmm just a question, bdebde said the Kyosho battery trays will be fine, but would the high of the LiPo not be a problem, it's 5 cm high?
http://e-savage.com/gallery/data/500...t_holder_1.jpg And if I see this, the length is good, but the hight of the LiPo? |
Finally, I bought a LST2 on eBay a few hours ago! :D
And I thought, and thought, and now I think the best setup for me would be: - NEU 1521/1D 2900Kv - NEU Energy 25C-50C 4900mAh 4s LiPo - Mamba Monster Max - RC-Monster 2 Speed pinion adapter 5mm bore - Self made motor mount So what about this? |
Stick with 5 or 6s. I have found that my 4500 30c 6s lipos are close to maxed out with the hacker 11xl. I am not sure if the 1521 will draw less amps, really do not think it will. I would stick with the 4900 5s pack and a lower kv motor.
| All times are GMT -4. The time now is 03:42 AM. |
