-   -   Sidewinder cuts out after a few min. (https://www.rc-monster.com/forum/showthread.php?t=14963)
e-mikey 09.11.2008 02:37 PM
Bet your glad it's not another dead MMM thread....
After about 4 min of racing, my sidewinder cuts out, then comes right back on. Can someone help my troubleshoot.
It's a sidewinder on 2s with a CC 5700 motor running a 16t pinion. The car is a zx-5.
I have removed the switch and soldered the power button. I knowit's not the battery. This only happens after a few min, maybe it's getting too hot and thermaling? The motor isn't very hot at all at this point. Haven't tried a temp gun yet.
Arct1k 09.11.2008 02:49 PM
The 5700 is a big AMP puller - I put it on my Eagletree with the Enerland 25C batteries and was seeing 100amp spike
e-mikey 09.11.2008 03:38 PM
So you're thinking it's pulling alot of amp deep into the race causing my LVC to trip?
MetalMan 09.11.2008 03:38 PM
Have you checked the temp on the Sidewinder when it cuts out? Do you have any cooling holes in the body to provide cooling air for the Sidewinder?
e-mikey 09.11.2008 03:40 PM
I had a 6400 15 true rc battery. The first qualifier it did it at the very end. I ran the next 5 min qualifuer with the same battery, cut out like 2 min in. The final race I had a fresh 6400 15c, made it to 4 min of the 6 min main.
e-mikey 09.11.2008 03:41 PM
No cooling holes, and I didn't check the sidewinder. I can tell you that the motor wasn't hot.
MetalMan 09.11.2008 03:44 PM
Well, without knowing the ESC temperature we can't say for sure whether or not it was thermalling.
TexasSP 09.11.2008 05:35 PM
Does the sidewinder beep like the MM when it thermals?
I thermaled my MM before several times doing speed runs with the 5700 on 3s and it would also beep at me when it did.
