-   -   Any Center Diffs for the E_REVO???? (https://www.rc-monster.com/forum/showthread.php?t=15001)
RevoRacer09 09.13.2008 05:03 AM
Anyone know who makes or if traxxas is gunna make a center diff for the E-Revo???
kevin23 09.14.2008 06:57 PM
traxxas has a part number for one,but not yet released as far as I know
lincpimp 09.14.2008 08:02 PM
I am working on one right now, and it will be a real center diff, not the 2 spider gear crap that traxxas sells... Just need to get my proto drawings to the machine shop...
sjcrss 09.14.2008 08:34 PM
well, lincpimp, if you have one in the works...then i guess I can forget about trying to figure out how to make one myself...using a diffcup & the 33t gear....do you have any mock up pics?
E-Revonut 09.14.2008 08:36 PM
Linc you could make yourself a small fortune if your design works!
kevin23 09.14.2008 09:44 PM
i would like to try a real diff,what kind of time are you thinking linc?
neweuser 09.16.2008 01:28 PM
I would like to incorporate the FLM Tranny case. Extend the lower ends for the diff to fit and bore out the bearing holes to fit the larger bearings. I think Mike and Jamie could figure this out to fit a 1/8 center diff for the hot bodies. It would be a bolt right up I think. Same concept as the slipperential only utilizing the the tranny more so and encased. I think this would also need custom drive shafts to fit, they would have to be a bit shorter. The good thing about this way would be no figuring where to put a motor mount I would think. Too bad I suck as CAD, otherwise I would get one figured out.
lincpimp 09.16.2008 01:52 PM
Not at the moment, but I plan to use the stock lower gear, and have it machined slightly. I will most likely use a kyosho/ofna diff cup and internals, as they are readily available and cheap. I need to give the machinist a ring gear to duplicate the internal portion of it and then modifiy the external area to accomodate the modded gear and space everything correctly. I would have to get custom output shafts made, or modify the existing output shaft to fit.
Not really looking to make much money, but I have quite a few designs that would sell well.
I would like to get to the machinist this week, as I need to get a KB shaft turned down to 5mm for Paralyzed... After that I could figure out the rest in a few evening and a couple of trips to the machinist.
Sounds interesting...
sjcrss 09.16.2008 04:31 PM
Linc, you idea sounds like the one i had, but the machinist i know, says he can modify gears, but as for making them, he won't.... my idea was to use a thunder tigre cup & internals, and mod the lower gear to mate up to the cup as well, and mod the shafts to work, but since your farther in, than i am, and have access to a machinist....i'll let you fly with it...and wait for the product.....and also sign me up for one as well....keep us informed....
lincpimp 09.16.2008 04:47 PM
I can do that. I dropped the parts off at the machinist today and should have something back in a few days. He is going to machine me something rough and I will measure and mock up with those pars and then get back to him with final measurements. Sounds like the easiest way at the moment.
sjcrss 09.16.2008 05:39 PM
sounds good linc, cant wait to see the rough one....
sjcrss 10.08.2008 02:20 PM
Well, I have a update for everyone....I got my modded ring gear back today, and I have one shaft allready made, I just need to get one more measurement for the last shaft, however I can post a few pics tonight, showing the ring gear that was modded along with a drawing of the specs for the ring gear and the shaft lengths ect....plus I will give a list of products needed to do this as well....
PICS to follow
lincpimp 10.08.2008 04:10 PM
Sounds good, I will be interested to see the pics.
sjcrss 10.08.2008 05:47 PM
here you go, I still need to work on the shafts, but it fits inside real good, just need to use 1 shim in front of gear and that is all, also at the back of the cup into the tranny, I used a 8X12 bearing, so here are the pics....
http://img.photobucket.com/albums/v4...Picture001.jpg
http://img.photobucket.com/albums/v4...Picture003.jpg
http://img.photobucket.com/albums/v4...Picture002.jpg
sjcrss 10.08.2008 06:19 PM
As you can tell the shafts need to be finished, however....the shaft at the back of the cup is 16/32 in length, & it needs to be 13/32 from the back of the tranny, and the front needs to be 13/32 as well, instead of 8/32...so at this time Im ordering a new lower shaft, and redo the shafts & get the correct lengths for everyone...to go by......so it's real close, and very cost effective as well..
