-   -   Who Still Has a Working MMM 'V1' (https://www.rc-monster.com/forum/showthread.php?t=15060)
DRIFT_BUGGY 09.15.2008 05:47 PM
Just wondering who still has a working MMM V1 and what Firmware you are running? I have only changed the settings on the ESC, I have never updated the Firmware from what it is out of the box
JerryF504 09.15.2008 05:54 PM
I have a working v1 with the original v1.17 firmware and a working v2 with v1.19 firmware.
hootie7159 09.15.2008 05:56 PM
i've got one as well...my MMMv1 is in my 8ight w/ updated firmware.....my MMMv2 is working as well in my muggy...
e-mike 09.15.2008 06:04 PM
two of my friend here have one unit ...each one still going strong:yes:
bruce750i 09.15.2008 06:09 PM
V1 still good, box stock, 1.19 on 6s
Cowboy 09.15.2008 07:01 PM
I have 2 that are still up and running 1.17 firmware on 6S, ccbec and fan wired to run off ccbec
gixxer 09.15.2008 07:26 PM
still working in my e-revo on 6s.
BrianG 09.15.2008 07:33 PM
Still working on 4s ATM with my mod, will go to 5s in the future.
Edumakated 09.15.2008 08:07 PM
My first two v1's went up in smoke, but my 3rd v1 is going strong with the original firm ware. I just cut the top of the case off and run with no fan. Works great. Temps typically about 150 - 170 after a 10 or 15 minute main.
I run 5s with a Neu 1512 3d or 1515 2.5d depending on how I feel that day.
jhautz 09.15.2008 08:22 PM
I have a V1 that is still working v1.17 software and It just went back into the XT8 truggy to replace the V2 that had a BEC failure. I originally pulled out of the truggy to replace it with the V2 I got in replacement for my first failed V1. Not allot of run time on it yet. Maybe 3 hours or so. My 2 other V1s lasted well past this long before the BEC died in them, so I'm still holding my breath. The V2 I had only made it an hour or 2 before the BEC went. I still have a V2 that hasn't been plugged in yet. Waiting for the V1 to go first.
RBMike 09.15.2008 09:14 PM
Edumakated, Internal bec?
lincpimp 09.15.2008 09:28 PM
Still have 1 v1 that works fine. Must have 1.17 firmware, as I do not remember changing it. I have played with the settings with the castle link quite a bit. Running 4s with a 1515 1.5d.
jnev 09.15.2008 09:30 PM
I have a V1 MMM (with no mods) that is going strong with lots of run time on it in my 8ight. I am using the stock firmware, or whatever it came withe when I bought it.
I also have a V2 MMM (with no mods as well) that is going strong too. :yes: I had a short test with it in my 8ight, and a short test with it in my CRT.5. I will have much more testing with it in the CRT.5 this upcoming weekend.
I also plan on buying one more MMM for my 8ight-T which will be running 6s. The 8ight and CRT.5 are both running 4s at the moment... but I can't be happier with the performance of the MMM's I currently have. :yes:
Edit: If anyone cares about the set ups, I am running a Hyperion 4s 5350mah pack in the 8ight with a Hitec HS-5997MG servo and Tekno Neu 1515/1y motor geared 47/17. And the CRT.5 has a Neu 1509/1.5y motor, Flightpower 4s 4370mah lipo pack and a Hitec HS-5245MG servo geared 46/16.
auto2 09.15.2008 09:42 PM
i do :-)
VintageMA 09.15.2008 09:44 PM
I have 2 v1 MMMs both with upgraded firmware working fine. Both running 6S with Neu 1515s and internal BEC.
