KB 45 XL got a competitor ?
I just found this, this guy is already selling some OEM Hobbywing ESC and feigao Motors
http://minizedeur.free.fr/catalog/ph...mparatif_4.jpg http://cbracingshop.com/catalog/prod...7c8f2c965f8996 |
Kinda expensive aint it? Reminds me of the velineon because of the hex screws.
It is quite expensive, but would be a nice option. For many it's nice that it has a standard 540 mounting pattern, but I don't like that. I prefer the 30mm spacing and 4mm bolts that the KB-45 uses. The screws holding the endbells on are a nice touch, though.
A legal BL motor for 1/10 scale racing is sold around 100 € these days... so it's no that expensive. Everthing sold in France take 19,6 % of TAX
maybe it will run cooler having so much more torque than just a standard XL, so who is gonna order one and test it out?
it is a hoss of a motor at 45mm diameter smooth can and XL length, and at 550 grams it out weighs all of the other motors we are using. i bet it would run good, prolly wouldnt get great runtime but you never know. |
i wonder who that is? because he also sells RC-monster stuff
Christophe Boulet
N. 1 allée Marguerite Givernis Résidence le Saint James Bât. A Apt. 35 34080 Montpellier - France - |
I think it said it has a 5mm shaft. At the bottom of the page, the pinion teeth are called dents. Thats different. I think thats close to $160.00:gasp:
6 pole motor too. Hmm.
Interesting find. I wonder if another vendor carries this motor. I'm not sure if this correlation can be applied, but running a mamba 280-sized motor in my mini-inferno was nothing but a heat pump. I switched to a 400-sized can with tons more torque and about half the kv value and got way better performance and reliability.
Excuse my French but,
Caractéristiques : 2150 Kv Bobinage 6 tours Max 120A Plus de 2000 Watts maxi Voltage max recommandé : 25V Diamètre : 45 mm Longueur : 76 mm Poids : 550 grammes Entre axe trous de fixation : 25 mm standard 540 Format équivalent à un Speed 700 en taille Axe moteur 5 mm avec méplat Rotor néodyme diamètre 24 mm Cage démontable Roulements énormes gros diamètre ultra résistants Câblés d'origine avec des prises PK 6 mm mâles It's all there in plain French? 6 pole?? |
Just looked up some comments on Feigao's 580 motor.. Doesn't seem suitable for car use according to some. Check it:
http://forums.radiocontrolzone.com/s...d.php?t=234845 |
2150 Kv 6 turns winding Max 120 Amps Power 2000 watts maximum adivsed Voltage : 25 volts (it will turn fast with such voltage ...) Diameter : 45 mm Lenght : 76 mm Weight : 550 grammes Space between mounting holes : 25 mm standard 540 size Equivalent to Speed 700 i term of size (Speed XXX it a reference to old brushed motor used in RC Aircraft) 5 mm output shaft with plane Neodymium Rotor with 24 mm diameter Dismountable housing /casing / stator Oversized ball bearing for long life Default wiring with Banana plug (PK) size 6 mm |
what does "very free wheeling" mean ? good for a tekno clutch system ?
| All times are GMT -4. The time now is 12:33 AM. |
