Motormount for a Nanda NRB-3?
Is there a motor mount for the Nanda Nrb-3 that fits with no mods?
I just got the mount for the mp777, the center diff is att the right hight, the mount is the right hight compared to the original centerdiff holder, the problems are that the diff comes to far back (app 2,6-2,8mm), the CC-measurements on the breaks are not the same, The top plate holes are not the same. If there is atleast a mount that will make the diff fit thats enough..... |
Hi!
The novak motormount for the inferno, fits almost perfect in the nrb-3. With a 11 tooth pinion, the mount just hits the rear support brace, but with a little violence it sits perfect. But you have to use the novak HV Pro systems, due to the special motor mount.. |
Ok... i am only interested in Mikes stuff.... |
| All times are GMT -4. The time now is 12:46 AM. |
