Mamba Max question
this question is about the regular mamba max, not the monster. I was out driving, and all of the sudden, it just stopped working and the led light was beeeping. so i shut it off, and went home...
then i plugged it back in and everything was fine....any ideas what caused it? my battery voltage was 12.44 when i checked it after the incident happend....i'm stumpted. |
Sounds like you thermalled it. Or it could be that it wasn't plugged into the rx properly. Seen that happen before.
i agree with the thermal. Best edumacated guess:lol:
Sounds like a thermal. I had that same issue when I had my tc4 running over geared on 4s. when it thermaled that was exactly what happened, led flashing. Let it cool a bit, all ok. that was my prompt to put a fan on it, yes should have geared down, but speed was not going to be sacrificed!
a CAP will help with about 10-15 degrees |
That MM has been moved to my zx5 where it gets run on 2s only. and back to stock, no fan, no bec. |
thanks guys....i just noticed that the esc fan wasn't plugged in.
| All times are GMT -4. The time now is 09:43 AM. |
